Welcome to MSFN Forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. This message will be removed once you have signed in.
Login to Account Create an Account
Problem in first test of running unattended cd
  • Please log in to reply
4 replies to this topic
#1
Lost Soul
Lost Soul
    Snap ... Crackle ... Pop
  • Member
  • PipPipPipPipPipPipPip
  • 1,746 posts
hi ive just finished most of my unattended xp pro cd except for drivers and other small things, so i wanted to test out my unattended xp pro disk and before i could get the disk to run after i got past the hit any button to boot blaa part,,, the next thing that poped up on my screen was this
Line 46 of the INF File \i386\winnt.sif is invalid
i have no ideal on how to fix this here is a copy of that file:
;SetupMgrTag
[Data]
AutoPartition=0
MsDosInitiated="0"
UnattendedInstall="Yes"
[Unattended]
UnattendMode=FullUnattended
Repartition=No
OemSkipEula=Yes
OemPreinstall=Yes
UnattendSwitch="yes"
TargetPath=\WINDOWS
[GuiUnattended]
AdminPassword=*
EncryptedAdminPassword=NO
OEMSkipRegional=1
TimeZone=35
OemSkipWelcome=1
[UserData]
ProductKey=
FullName="Dream Weaver"
OrgName=""
ComputerName=DEFAULT
[TapiLocation]
CountryCode=1
[RegionalSettings]
LanguageGroup=1
[Identification]
JoinWorkgroup=WORKGROUP
[Networking]
InstallDefaultComponents=Yes
[Shell]
CustomDefaultThemeFile="%Systemroot%\Resources\Themes\Silver.theme"
[GuiRunOnce]
%systemdrive%\install\hotfixes\hotfixes.cmd
%systemdrive%\install\batch_file.cmd
bootcfg /RAW /A /Kernel=OEMKrnl.exe /ID 1
bootcfg /Timeout 0
can any one see where i went wrong or what the problem is ? right now im puzzled
thanks
lost soul
This is not the end. It is not even the beginning of the end. But, it is, perhaps, the end of the beginning.
- Winston Churchill
How to remove advertisement from MSFN
#2
Aaron
Aaron
    The MSFN Banana
  • Patrons
  • 5,767 posts
  • OS:Windows 7 x64
  • Country: Country Flag
bootcfg /RAW /A /Kernel=OEMKrnl.exe /ID 1 is line 46, I don't think this entry is supposed to be under [GuiRunOnce], but someone else will help you on the matter as I haven't done this bit before.
#3
XtremeMaC
XtremeMaC
    MSFN SuperB
  • Member
  • PipPipPipPipPipPipPipPipPipPip
  • 5,070 posts
  • OS:Windows 7 x64
1st remove the key maybe :)
2nd if you open up "notepad" and go to "view" and select view "status bar"
u'll be able to see the line numbers..
and bootcfg I think is a recovery command I don't know anything about it but it might not work?&*^%#$%
windows doesn't have that file "bootcfg"
at least mine doesn't. but windows setup has it.
try putting it on a batch file and run it on the cd without copying to hdd.
Edited by XtremeMaC, 13 December 2003 - 11:02 AM.
#4
Lost Soul
Lost Soul
  • Member
  • 1,746 posts
ok ive deleated the last 2 lines which were part of a camd to get the custom bootscreen to work,
now ive changed the cmd and made a bootlogo.cmd file, now im gonna do my next test.. i hope it works ,,, when i first put them lines in guirunonce potion, i took that information from this thread
http://board.MSFN.or...?showtopic=9421
well im off to test it again i hope for the best, if any body has any more ideals let me know
- Winston Churchill
#5
Lost Soul
Lost Soul
  • Member
  • 1,746 posts
well i just tested my cd again and now it worked you can say half and half it needs some bugs worked out, im gonna try to figure them out but if i cant im posting more :)
- Winston Churchill
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
