MSFN Forum: NLite installation problem (ISO creation will do nothing) - MSFN Forum
If you are having issues with Windows after removing components and have come to ask for help, please attach (not paste) your Last Session.ini file to your post to facilitate quicker assistance.
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
NLite installation problem (ISO creation will do nothing) v1.4.9.1 Rate Topic: -----
#1 User is offline   Kethar
  • Group: Members
Posted 27 September 2008 - 11:13 AM
I've installed NLite v1.4.9.1, do something with installation CD contents and try to make ISO. In this step, nLite process do nothing! I've tried to reinstall, and run from extracted nLite (w/o install).
There're bug: file nhelper.exe is packed!!! why?!!!
Please, unpack this!!!
#2 User is offline   MCT
  • MSFN Junkie
  • PipPipPipPipPipPipPipPipPip
  • Group: Members
Posted 27 September 2008 - 12:56 PM
that file is a cab file which is still cabbed for me..
nhelper.ex_ is a 40kb file
bfe4798b7c882ad11d9a0bc8173e2d05 is the hash of that file..
also try redownloading your nlite program?
#3 User is offline   Kethar
  • Group: Members
Posted 27 September 2008 - 12:59 PM
yes, I say about above. nhelper.ex_ is compressed exe file (possibly in cabinet format, same as used within windows setup. I use 7zip to unpack).
How-to-repeat: remove your installation, install program (this version), try to make ISO file with default options.
PS: previous versoins contains correct exe file.
This post has been edited by Kethar: 27 September 2008 - 01:03 PM
#4 User is offline   MCT
  • MSFN Junkie
  • Group: Members
Posted 27 September 2008 - 01:13 PM
do u have the runtime files for nlite? see here:
http://www.nliteos.com/download.html
not sure if it will help or not, but worth a shot, anyways post back & let me know
#5 User is offline   Kethar
  • Group: Members
Posted 27 September 2008 - 01:14 PM
YES!!!!!!!
#6 User is offline   Kethar
  • Group: Members
I will not put topic here, if I is not sure in problem
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Copyright © 2001 - 2011 msfn.org
Privacy Policy
