I was tring to help a friend with his Compaq Presario 2145 laptop. He wanted to do a fresh install of winXP (we tried XP Pro and Home) , so we used the XP Home disk that came with the system and after it installed the external switch for the Lan-Express will not work. This switch allows you to turn on or off the wireless card and it has a small blue light that indicates data communication and power. Ive downloaded the drivers and everything and still no luck.
The LAN card actually works fine, just the external power button and light doesnt work. I can turn it off with software.
I then did a system restore with the system restore disk and it started working. However, we dont want to restore the system like this because it adds in all of the other crap software we dont want.
Summary: light works if using a restore disk but will not work if just using a windowsXP disk to install OS.
So anyone have any ideas?
Is there anything I can copy to disk from the working restore over to the just XP version?
thanks
TWILL
Help
Back to top
