mike13 Posted June 30, 2015 Share Posted June 30, 2015 I just downloaded and installed Windows 10 build #10158 to my test computer. All went well as far as I can tell. However when I place the mouse over the battery icon down on the taskbar, I get this popup "96% available, plugged in, (not charging)" I doubt Windows 10 has anything to do with this, but before I contact the person that I bought the battery from, I just wanted to make sure. The battery is about 6 months old. It is for Dell Inspiron. There is a light on the charging unit, that is glowing green. That usually means it is charging ?? I never noticed this before. Is there a way to check to see if the charger is really working , or could build 10158 caused this ?? Thanks, Mike Link to comment Share on other sites More sharing options...
mike13 Posted July 1, 2015 Author Share Posted July 1, 2015 Update----I pulled the charger plug from the computer, and let it discharge down to 90%. Then I plugged the cord back in, and it charged to 100%. So all is good. Not sure if it was Windows 10, (I doubt it), but all is good now. Mike Link to comment Share on other sites More sharing options...
kaljukass Posted July 1, 2015 Share Posted July 1, 2015 Now is once again time to update, version 10159 released yesterday... Link to comment Share on other sites More sharing options...
Tripredacus Posted July 1, 2015 Share Posted July 1, 2015 See if there is any Battery software available from Dell for that model notebook. Link to comment Share on other sites More sharing options...
