Hi everyone .
i am new in the forum :-)
and i am trying to use hfslip with win2k
i followed the instruction...
i created win2k with sp5 and ie6 and dx9 and hebrew language supp .
after i created the i ran it with virtual pc 4 and in the installation while
"Setup is loading files(Machine Identification Data)..."
i got the following message:
Line 51 of the INF file is invalid
Setup cannot continue. Press any key to exit...
i tried to change few files but i dont know what is the prob.
hope someone help me in this because i ran out of ideas.
i added the error_report file
thanks
ERROR_REPORT.zip
Welcome to the forum, roiysh! :hello:
Probably a stupid question, but do you have the ident files (CDROM_IP.5, CDROM_NT.5, and CDROMSP4.TST) in SOURCE? Also, make sure your SOURCE works. Remember, running HFSLIP won't fix a bad source (garbage in, garbage out).
Also, I don't exactly recommend slipstreaming Hebrew IE hotfixes into an English system.
I'm not too familiar with INF files, so maybe someone else on this forum will be able to help you better. Try running the April 1 version of HFSLIP and report back.
Edited by Super-Magician
Two suggestions for now...
1) As Super-Magician says, don't slipstream Hebrew hotfixes into an English system
2) If you want support for the latest hotfixes, you need to use the latest test release (which you seem to have but didn't use)
i am using win2k sp4 .
i used 3 vers of hfslip (all that listed in error_report)
the latest try i used was with ver HFSLIP_60417-rc3.CMD
i putted all the files cdrom etc in the currect directory...
and removed all ie6 heb fixes and the same result...
i make one win iso installation and it worked .
i believe it is in my winnt.sif it is possible i add it.
i will try another run without the winnt.sif
thanks for the fast reply
WINNT.zip
